john.reasor@aaon.com
Update Azure pipeline build
Tue Aug 09, 2022 2:35 pm
I need to complete the Update task on an Azure Pipeline build I can build the .msi file without issues but the Update task does not see the resulting .msi file how do I set the file location on the pipeline?
Below is the related script.
task: AdvancedInstaller@2
  displayName: 'Create Ecat6Setup'
  inputs:
    advinstLicense: '$(AILicense)'
    aipPath: 'ECATSetup_Temp\\ECATSetup-Azure.aip'
    aipBuild: 'Ecat6Setup'
    aipPackageName: 'Ecat6Setup.msi'
    aipOutputFolder: '$(Build.ArtifactStagingDirectory)\MSI'
    aipExtraCommands: 'SetVersion $(MainInstallerversion)'
- task: PublishBuildArtifacts@1
  displayName: 'Publish msi and files to Artifacts page'
  inputs:
    PathtoPublish: '$(Build.ArtifactStagingDirectory)'
    ArtifactName: 'ecat6'
    publishLocation: 'Container'
- task: AdvancedInstaller@2
  inputs:
    aipPath: 'ECATSetup_Temp\\ECATUpdate-Azure.aip'
    aipBuild: 'ECATUpdate-Azure'
    aipExtraCommands: NewUpdate $(Build.ArtifactStagingDirectory) -name Ecat6Setup.msi /AddUpdateReplacement $(UpdateName) -replace_all -url $(Build.ArtifactStagingDirectory)\MSI\ecatupdaterconfig.txt
  inputs:
Re: Update Azure pipeline build
Wed Aug 10, 2022 12:13 pm
Hello John and welcome to our forums,
Please have a look over the following forum thread where my colleague Daniel explains how to achieve this:
Re: Azure DevOps and Advanced Installer issue
Basically, the MSI/EXE resulted from building your .AIP file should be added into the repository, relative to the path of the Updates Configuration Project.
Additionally, please have a look over the following blog article which does the same using PowerShell:
How to Generate Updates Configuration File in Azure DevOps pipelines with Advanced Installer PowerShell Automation
