mcseforsale
Customer asked to install files in roaming profile path
Our customer wants to drop files in the users' roaming profile appdata location. Where in Advanced Installer folder paths is: C:\Users{UserName}\AppData\Roaming?
Thanks!
AJ
Re: Customer asked to install files in roaming profile path
Hello AJ,
In order to achieve this, you can add your files under the "User Profile" --> "Application Data" folder in the "Files and Folders" page.
For more details about the folder paths, you can check our Paths of the folders in the "Files and Folders" Page article.
If you have any other questions, please don’t hesitate to contact us.
runbikelive
Thank you for the suggestion Liviu.
I would like to provide the option for the installation to be installed per-user or per-machine.
For the per-machine administrator installations, I prefer using the program files location.
For the per-user installation local profile path rather than the roaming profile path is used. Is there a way this can be adjusted to the roaming profile path?
If you have the "per-machine if user is administrator, per-user otherwise" installation type, then please note the path of the APPDIR ("Files and Folders" page --> "Application Folder") is configured automatically at install time, based on the user's choice in the "InstallTypeDlg" dialog.
The per-user location we are using (which is recommended) is %appdata% which resolves automatically to: C:\Users\Catalin\AppData\Roaming.
If you would like to add your files in the AppData\Local folder, you could try using the "Local Application Data" folder from the "Files and Folders" page.
runbikelive
Thank you for your reply Catalin. Unfortunately, my installation is acting differently than expected.
I would expect my per-user installation to install to the "roaming" folder location. For some reason it is installing to the "local" folder location.
When I check my system path for %appdata%, it properly resolves to the roaming location. During the installation, I am shown the local path as follow:
C:\Users\<username>\AppData\Local\Programs\CAS\Updater Testing
I am running the trial version of AI v20.1.1.
Is there something else I may be overlooking?
It looks like I misunderstood your requirement, please accept my apologies for that.
Also please ignore my last reply as I was wrong. Indeed, as you mentioned, for the per-user option, the path is resolved to the Local/Programs folder.
In order to achieve what you want, you can proceed as it follows:
- on the "Next" button of the "InstallTypeDlg" dialog, you can create a "Published Event" as it folllows:
This way, we will automatically set the path to %appdata% if the user selects the "per-user" option.
runbikelive
Thank you Catalin, your response was most helpful.
For others looking for the same solution, I slightly adjusted the argument as follows:
[AppDataFolder][Manufacturer]\[ProductName]\
This will maintain consistency using the manufacturer and product name. Optionally, some may wish to include "[Programs]\", before the manufacturer, to remain consistent with how some other applications install.
Thank you again!
Tom
You are always welcome, Tom!
Glad I could help!
