NigelShaw
Updated on local network
Hey
Im having a bit of trouble with this.
When using a network location, can i use a location that isnt mapped like
file://ServerFolder/AppFolder/App
instead of
file://S:/AppFolder/app
we dont a mapped drives with an assigned letter, we use the full UNC path. i need to put my updates.txt file & update.exe into a network folder location and tell my installer & updater to look in the network folder.
currently im getting an error 'Checking for Updates - The system cannot find the path specified'
Re: Updated on local network
Yes, this should be possible.
Did you checked the forum thread I posted to you in another thread you opened? There was an example of this scenario.
Please check my reply with detailed steps on the forum thread here.
You can use a location like this: "file://\\DESKTOP-MUA5C29\updater\updates.txt". Just add the double backslash before your location name.
