mpande
Prevent Upgrade if not Licensed
If the license check flags are set "LicenseCheckFlags = FailOnServerError|FailOnWrongRetCode" in the aiu file like so
;aiu;
[General]
LicenseIdCheckURL = https://MySite.net/LicenseCheck
[MySoftware 2022.3.0919.0]
Running the command Updater.exe /silentall -nofreqcheck -nogui HKLM\SOFTWARE\WOW6432Node\License will check the license and either accept or reject the upgrade correctly.
Running the command Updater.exe /silentall -nofreqcheck -nogui or double clicking on Updater.exe will not check the license and will go ahead and upgrade this. Is there a way to control this?
Re: Prevent Upgrade if not Licensed
Hello Max,
From what I can see, you have already discusses this with my colleague Daniel in the following thread:
Using licenses to control upgrades
mpande
At that time we were trying to get the license check working correctly. Now we are trying to prevent users from skipping the license check. I take it there is no way to control this?
Hello Max,
In the forum thread I've linked above, you can see that there are two options my colleague Daniel has highlighted:
If I understand correctly, this is what you want to achieve.
mpande
To be clear we are checking those two checkboxes, which is why the file has the tags
The tags do work correctly when updater is called with the reg key as an argument. They do not work when the updater is called without the reg key as an argument.
Hello Max,
The updater has to be called that way in order for this to work.
Please let me know if you have any other questions and I will gladly assist.
