RambosRide
Error 1606 Network access to Cab file fails Web installer
I have a web installer outputting an exe, msi and 2 cab files.
AI Installer script was working for me less than a month ago pointing to files on Amazon S3 but this morning when I dropped a new build I get the error as soon as it tries to download GameFiles.cab (2gb in size)
We were going to transition to CDN77 service to distribute our files, so swapped to that and got the same Error 1606.
I've looked through the other forum posts on this error and nothing stands out and other posts are very old.
I've attached a screenshot of partial Log.
Thanks ahead for any help!
Re: Error 1606 Network access to Cab file fails Web installer
Hello Dan,
I'm not quite sure why this happens.
You can also have a look on the Web Installer unable to download CAB file forum thread which debates the same error.
In order for us to further investigate this, can you please forward to us by email to support at advancedinstaller dot com the following resources:
1. your .AIP (setup project) file.
2. a download link for your setup package.
3. an installation log.
RambosRide
I figured it out last night.
Cab files are limited to 2GB.. AI was compiling web installer cab at just above 2GB so failed with the horrible Error 1606 which is very non-informative.
Why can't AI chunk out cab files < 2gb when doing a Web installer?
I manually moved files to Features to get around but your software should be smarter to not compile cabs that break an installation?
I'm not sure why this happens. We treat this case (when the CAB file is larger than 2 GB) and an error is displayed at build time:
cab file.png (212.7 KiB) Viewed 3121 times
Can you please forward to us:
1. your .AIP (setup project) file with the settings at the time the problem occurred (before you fixed this by moving the files in Features).
2. and a download link for your setup package.
by email to support at advancedinstaller dot com so we can have a look on this?
