Henrique Mesquita
Failed to uninstall more than one exe
My application installs another three applications (later there may be more) as prerequisites. At the time of uninstalling the "parent" application we want to remove all prerequisites together.
We follow the user guide instructions: https://www.advancedinstaller.com/user- ... l-msi.html. Where we got the following scenario: removing the "parent" application it only removes one or two of the three applications we have, never all three. If we leave in the project, the custom action to remove only the prerequisite that was not previously removed, it removes it, proving that it is not a fault of the custom action. The three custom actions are exactly the same, changing only the respective GUID of each "child" application. The command used is "/x {GUID} /qn .
We tried to perform this procedure using "Uninstall using this command line:" on the "Prerequisites" page, link: https://www.advancedinstaller.com/user- ... files.html, in order to work around the incident cited earlier. However, we did not find a valid command.
Could you support us by informing us how the command should be or understanding why it is not working the other way?
Re: Failed to uninstall more than one exe
I'm not sure why this happens.
Can you please send us the .AIP (setup project) file, your prerequisite packages (if not added using URL) and an uninstallation log by email to support at advancedinstaller dot com so we can further test and investigate this?
Henrique Mesquita
Hello!
Before sending you our project, could you let us know the correct command we need to pass in the path "Uninstall using this command line:" in the "Prerequisites" according to the attached image? Perhaps this procedure works around the error we are having when uninstalling via custom actions, all our prerequisite packages were also generated by the advcanced installer and they are all .exe packages.
Everything should work as expected with the default command line:
maintenance cmd.png (6.8 KiB) Viewed 8546 times
Henrique Mesquita
Using the informed command line it worked as expected, thank you!
You're always welcome!
