wingers
Advanced Installer Updater no longer working due to recent OV code signing certificate changes – complete nightmare!
For years as a sole-trader I have had an OV code signing certificate showing my business name, due to the recent changes in validation for issuing of OV certificates you are no longer allowed to have business name on a certificate unless you are a registered business and “the business has to be registered on their local government business directory where the entity can be searched”, so for sole-traders and independent developers you can only have your individual name. - https://signmycode.com/resources/change ... june-2023
I chose Advanced Installer many years ago to package my products mainly for one feature and that was its Advanced Updater and the “Install support service” option so you can install updates without elevation under restricted user accounts (https://www.advancedinstaller.com/user- ... avior.html) – the reason being a lot of my products are used by enterprises so installed on locked down computers where standard users don’t have admin rights, and this allowed me to easily roll out regular updates to my products that would install silently without any user interaction or needing admin rights or UAC elevation.
This has worked perfectly for me for many years.
Until now……
Because of the signing changes my new certificate contains my name “Darren Rose” rather than my business name “PC Assist” in the subject field and this has completely broken the update process……….
So now when I try and update my apps instead of them running silently like they did before the installer pops up on screen likes a normal installer and expects the user to click Next etc to continue the install
• I have never had the “Install only digital signed update packages signed with the same certificate as the Updater” check box enabled in my apps
• When I call the updater.exe from within my app I pass the /silentall argument
• The updater.ini in my app directory has the NoUpdaterInstallGUI Flag set – from checking the below in project:
• My updates.txt that is on the server along with my new msi file looks like below (URL removed for security) – and has the Flag for SilentInstall
;aiu;
[Update]
Name = AppName
ProductVersion = 5.8.3.0
URL = ****REMOVED****
Size = 8799232
ServerFileName = update.msi
CommandLine = /L*V "C:\windows\temp\deskmon.log"
Flags = SilentInstall|NoCache|Advertises
RegistryKey = HKUD\Software\PC Assist Software\AppName\Version
Version = 5.8.3.0
As I say this all works perfectly fine if the update I release has the same certificate as the version currently installed uses, the update silently installs with no windows or prompts showing.
But when trying to roll out a new version using my newly issued certificate then for some reason it completely ignores the fact it should be running the update silently and instead the installer window pops up on screen.
If I manually install the MSI using the /qn switch rather than relying on Advanced Installers updater then it works perfectly fine – showing that the change of certificate isn’t the problem, it is the fact that Advanced Installers updater.exe compares the subject field before doing updates and that there is no way of turning this off – as covered in other threads.
This issue has caused me major headaches, I can’t manually update my tools on tens of thousands of client computers I don’t have admin access too, and if my updates fail on all of them it could be very embarrassing and has the potential to ruin my business.
Surely, I can’t be the only person with this issue – especially now since 1st June with these changes to the certificate issuing / validation process? surely lots of Advanced Installer customers are independent developers / sole traders, not just all big enterprises? So when they renew certificates next will potentially be encountering the issue of having certificates with different subjects.
After no response at all from support@advancedinstaller.com for all the emails I have sent in the last 3 days (makes me wonder why I renew my maintenance each and every year!) – website says “We will usually answer your email within 24 hours, but most often within minutes of receiving it.”, so not quite sure what has happened this week…. Anyway means I have had to spend numerous hours when I should be out earning money working on a solution to this problem instead, as my existing certificate runs out very soon so time is against me!
Turns out the solution is as per the section “Migrating to a new certificate” on this page - https://www.advancedinstaller.com/user- ... dates.html - BUT following it exactly as written didn't work as it was missing an important step, and it has taken me a while to work out why. All the forum articles I read discussing similar issues keep pointing back to this article, but however many times I tried it, I still had the same problem.
Eventually I noticed that even after rolling out an update after following these steps that the updater.exe in my app directory still had the old certificate not the new certificate, despite following the steps exactly e.g. making sure that updater.exe was signed with new certificate and was in a folder with properties set to "install folder content into the parent folder" and that the "Digitally sign the file" option was disabled, it simply wasn't working.
Solution below:
wingers
Re: Advanced Installer Updater no longer working due to recent OV code signing certificate changes – complete nightmare!
So after spending two days going backwards and forwards with this and getting nowhere, as above I noticed that the instructions were missing a key step which meant the updater.exe you were signing with the new certificate was never getting copied over the original one signed with the old certificate during install and that was why it was not working.
Because the default setting on the operations tab of the properties of your updater.exe is "Overwrite only if the existing file is older" it wasn't actually overwriting it - so change it to "Always overwrite existing file" and voila the instructions actually worked and I can now work on the tedium of having to role out updates to all my apps containing the updater.exe with new certificate, just to allow me to then roll out future updates.
Surely it would be so much easier if Advanced Installer just had a switch or something to allow you to skip checking the subject or were not so strict on it! especially with the new OV rules mean that lots of sole traders and independent developers will possibly be facing the same issue upon renewal!
Anyway at least it is hopefully now resolved - testing has been done with a self-signed cert as my real new certificate (which now has to come on a bloody token from the US to UK) doesn't arrive until later this week.
Thank goodness I persisted as was no good relying on the support response my maintenance pays for.......
Hello Darren,
First of all, I am glad you managed to get this working.
Regarding the unfortunate delay, I have replied to you over the email and have explained why this happened.
We apologize for this inconvenience and thank you for your understanding!
