ankur
How to use code signing certificate from Yubico HSM Key Token
Due to recent changes around code signing, we have bought a new certificate from Sectigo using Yubico key token. The certificate issued is not a .pfx. Can you please suggest how can I use the new format certificate to sign?
I have tried to use from the certificate store (by exporting and then importing on my local machine) but it still fails.
Ankur
Re: How to use code signing certificate from Yubico HSM Key Token
Hello Ankur,
If possible, could you please have a look over the following article:
How to use the USB eToken for Extended Validation Code Signing in Advanced Installer
and let me know if it helps?
ankur
Yes I did read that article as well before. Thanks.
The problem I am facing is that I don't get a dropdown when I select the radio button option "use file from disk". Instead I get a popup to select the certificate file (see the attached image).
Please note that I am on version 17.3 of Advanced Installer. Is there any issue with that?
Thanks!
Ankur
ankur
Sorry I didn't see your other reply here. You have already answered my question on that post.
viewtopic.php?f=5&t=51563&p=131239&hilit=ankur#p131239
Thanks a lot for your help!
You are always welcome, Ankur!
