RuudHartog
Setting install parameter based on operating system name
I have an install parameter (property) which I would like to modify based on the operating system name
Tried a custom action with below VB script
prop = Session.Property("ISVDI")
propNew = Session.Property("ISVDI")
If prop = "false" Then
	strComputer = "."
	Set objWMIService = GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
	Set OSName = objWMIService.ExecQuery ("Select Name from Win32_OperatingSystem")
  If OSName.Contains("Virtual") Then
			propNew = "true"
	End If
End If
Session.Property("ISVDI") = propNew
But somehow this fails.
Anyone have a clue what's wrong ?
Re: Setting install parameter based on operating system name
There is a problem with your script. I have tested the vbscript outside the Advanced Installer and it does not work.
The error you're encountering seems to be related to the use of the Contains method. The error message "Object doesn't support this property or method: 'OSName.Contains'" suggests that the Contains method is not supported on the object type you're using.
To achieve the desired functionality, you might need to modify your script. Here's a revised version that uses the InStr function to check if the string "Win" is contained within the Name property:
prop = Session.Property("TEST")
propNew = Session.Property("TEST")
	strComputer = "."
	For Each os In OSName
		If InStr(os.Name, "Win") > 0 Then
			propNew = "true"
			Exit For
		End If
	Next
End If
Session.Property("TEST") = propNew
In this version, the InStr function is used to check if the string "Win" is present in the Name property of each operating system instance.
Replace the TEST property name with your property name.
Please give this modified script a try and see if it resolves the error you're encountering.
RuudHartog
Thanks Liviu,
Works great !
Appreciate your support
You're very welcome!
I'm glad to hear that it worked for you.
If you have any more questions or need further assistance in the future, don't hesitate to reach out. Have a great day!
