japandave1
Folder opens unexpectedly after installation?
I am having an issue where an ~~arbitray~~ Edit(C:\WINDOWS\SysWOW64) folder opens unexpectedly after installation? For context, I did try to make an updater using this https://www.advancedinstaller.com/user- ... dater.html guide. But it did not work as I expected. How do I stop this action of a folder opening after install?
Cheers Dave
Re: Folder opens unexpectedly after installation?
Hello Dave,
That folder appears most likely due to a Launch File action that can not find the file.
In "Dialogs" page --> "ExitDlg" please make sure you do not have these two options enabled:
Additionally, please make sure there isn't any unwanted "Launch File" custom action in the "Custom Actions" page.
