xObay
Google Chrome Like Software Updates
Where can I find details on implementing silent updates the same way Google Chrome or Visual Studio Code works?
I need to have my application check for updates in the background, download and install and prompt the user to restart to see the new version with no user intervention aside from restarting the app.
Obay
xObay
Re: Google Chrome Like Software Updates
Does the lack of reply mean this is not possible using Advanced Installer?
Hello Obay,
Apologies for the delayed reply.
In order to achieve what you want, we need to make use of the updater's command options - Advanced Installer Updater.
For instance, in your case, we can make use of the /silentall parameter.
Now, in order to achieve that, we have to automatically call the updater with the above parameter. To do so, we have two options:
1. create the updater as a service (using the "Install Support Service")
2. create a scheduled task to run the updater daily, for instance at LogOn
The next step would be to tell the updater to silently install the update. This can be done from the Updates Configuration Project --> "Update Installer" tab --> "Command line" field.
