lllgnslbdllssr
JSON file not edited during/after installation
Hi, I've created an appsettings.json and I have a field that is set by [Property]. I set this property using a Custom Action "Run PowerShell inline Script", but after the installation, this field in appsettings.json file is empty.
The powershell script is:
$dbPassword = AI_GetMsiProperty DB_PASSWORD
$errorMessage
$connectionString
if ([string]::IsNullOrEmpty($databaseNamedInstance))
	$errorMessage = "Database Name cannot be empty!"
else
	if ($useIntegratedSecurity -eq "useIntegratedSecurity")
		$connectionString = "Server=" + $databaseNamedInstance + ";Database=thisDB;Trusted_Connection=True;MultipleActiveResultSets=true;Encrypt=true;TrustServerCertificate=true;"
	else
		if ((-not [string]::IsNullOrEmpty($dbUser)) -and (-not [string]::IsNullOrEmpty($dbPassword)))
			$connectionString = "Server=" + $databaseNamedInstance + ";Database=thisDB;User id=" + $dbUser + ";Password=" + $dbPassword + ";MultipleActiveResultSets=true;Encrypt=true;TrustServerCertificate=true;"
		else
			$errorMessage = "Database username and password cannot be empty if you don't use integrated security"
if (-not [string]::IsNullOrEmpty($errorMessage))
	AI_SetMsiProperty CHECK_DB_CONNECTION_PARAMETERS "false"
	[System.Reflection.Assembly]::LoadWithPartialName('System.Windows.Forms')
	[System.Windows.Forms.MessageBox]::Show($errorMessage)
else
	AI_SetMsiProperty CHECK_DB_CONNECTION_PARAMETERS "true"
	AI_SetMsiProperty DB_CONNECTION_STRING $connectionString
This script works because I print DB_CONNECTION_STRING value and it is populated.
What am I doing wrong?
Re: JSON file not edited during/after installation
This can happen if the PowerShell script is scheduled after the json file is created/updated.
Can you please check if you scheduled the script before the Add resources action group?
Otherwise, can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
