MGS
Add dictionary using relative path to repository
I want the following:
  • Add the additional installer data (= Repository) to version control
  • Add all translated strings to this location as well, thus as I understand it the un_de.ail, un_en.ail (for changes in the default English and German translations inside the Project Strings) and a dictionary.ail (containing all newly added resources)
For the first step, I had a look at the following link to move the repository location inside my version-controlled folder (that was easy):
https://www.advancedinstaller.com/user- ... nager.html
Next, to achieve the second step, I added my dictionary.ail to the "dictionaries" folder in the new Repository location. The "un_de.ail" and "un_en.ail" were already there. Next, I verified the paths to those dictionaries are correct in the Translations view.
It looked like this in the beginning:
[a long absolute path]\dictionary.ail
<AI_REPOSITORY>dictionaries\ui_de.ail
<AI_REPOSITORY>dictionaries\ui_en.ail
<AI_DICTS>ui_de.ail
<AI_DICTS>ui_en.ail
<AI_DICTS>ui.ail
Now, I wanted "dictionary.ail" to also be added like that: "<AI_REPOSITORY>dictionaries\dictionary.ail". How to achieve that? Always when I press "Add" it uses the absolute path. I also tried to use the import-button, but I couldn't figure out what it did, there were no obvious changes.
Johannes
Re: Add dictionary using relative path to repository
Hello Johannes,
Sorry for the delayed reply on this.
I've tried to reproduce this, but it worked for me.
The Convert Paths option is not working as expected for you?
convert paths.png (144 KiB) Viewed 8030 times
MGS
Hello Liviu,
No worries.
If I only use the "Add" button without the "Convert paths" option, the absolute path is added always. I overlooked the function (the buttons) to convert the absolute paths to relative paths. Thanks for pointing out these buttons, that worked great :)
Johannes
You're always welcome, Johannes!
Glad to hear that this has helped you.
