KraigK
Install prerequisite from command prompt, not Powershell
I'm trying to install a driver package in silent mode and per their documentation, this is the command needed:
"Zebra CoreScanner Driver (64bit)" -s -f1"zebradriversetup.iss"
When I run this from C:\Windows\systems32.cmd.exe it works just fine. When I tried to build an MSI with it in the prerequisite section, it does not work. I think I've finally figured out that it is launching PowerShell instead. Trying the above command in PS does not work manually.
So how do I fix this?
KraigK
Re: Install prerequisite from command prompt, not Powershell
If I create a batch file with this line, this works when I just run the batch file manually.
Zebra_CoreScanner_Driver -s -f1"c:\kak\zebradriversetup.iss"
I'm not sure why this doesn't work in the PreReq section.
KraigK
I just tried copying the exe and associated files to a known folder, then running a batch file and it does not work.
Command prompt opens, it appears to be installing but it doesn't.
KraigK
Turns out the Driver package behavior is inconsistent with the silent switch. I ended up using the SDK package and it works is the PreReq section.
Maybe this will help someone in the future.
Thank you for your followup on this. I am sure this will help others who are facing a similar scenario.
You are always welcome, James!
I'm glad to hear Kraig's answer helped you. :)
