kevintran1308
Full tutorial how to use Advanced Installer with Azure Devops
Hi every one,
Do you where I can find the complete Advanced Installer tutorial to build the MSI package with Azure Devops CI/CD Pipeline?
I confuse after read all the posts.
For example, my application need to build on Azure Devops Service so I have a build computer for that.
However, do I need to install Advanced installer on that Build Computer to build the MSI package?
How do I config the Advanced Installer so that MSI would have all the features and functions that I want by automatic build by CI/CD Pipeline?
How can I find the documentation for Advanced Installer Yml Task to know about what Argument that task has?
Thank you
Kevin
Re: Full tutorial how to use Advanced Installer with Azure Devops
Hello Kevin,
We have a few articles related to Azure DevOps.
Here's a link that contains them:
Advanced Installer for Azure DevOps
Here's one that showcases how to build your Advanced Installer project using Azure DevOps:
Dedicated build of Advanced Installer setup project within Azure DevOps
If you are encountering any issues, please let me know and I will gladly assist.
kevintran1308
Thanks for replying me.
We have 5 Users Subscription.
How can I take the License Key for the assigned account?
Thank you
Kevin
Hey Kevin,
Please note that all 5 "accounts" will have the same Advanced Installer license key.
Or did I perhaps misunderstood your question here? If so, please give me some more details so I can better understand.
