valiot
Updater fails to install update with strange permissions error
I created an installer and enabled the updater feature. When I test the updater, it fails to perform the update. The new installer is located on the web server along with the updater text file. I also enabled the install support service as recommended.
When I check the Event Viewer I see the following System message:
The machine-default permission settings do not grant Local Activation permission for the COM Server application with CLSID
{C2F03A33-21F5-47FA-B4BB-156362A2F239}
 and APPID
{316CDED5-E4AE-4B15-9113-7055D84DCC97}
 to the user MICHAELAVISFAAD\MichaelA SID (S-1-5-21-3850368090-3868319105-2747544125-1000) from address LocalHost (Using LRPC) running in the application container Microsoft.Windows.ShellExperienceHost_10.0.19041.4239_neutral_neutral_cw5n1h2txyewy SID (S-1-15-2-155514346-2573954481-755741238-1654018636-1233331829-3075935687-2861478708). This security permission can be modified using the Component Services administrative tool.
valiot
Re: Updater fails to install update with strange permissions error
I can attach my aip files of the main app builder and the updater builder if needed
This looks like a system error that is specific to your machine, rather than something on our side.
If possible, could you please test this on multiple machines and let me know if you can reproduce this on multiple machines?
If you manage to reproduce this on multiple machines, i would advise creating a log file for the updater, as described in the following article:
Advanced Installer Updater
Additionally, the msi log would also be useful here (the MSI log can be created automatically by adding the log option in the Updater Configuration File --> Update Installer tab --> Command Line field).
After doing so, please forward me these logs file by email at support at advancedinstaller dot com.
valiot
I resolved this issue. I was using a really old version of Advanced Installer 15.9. I upgraded my projects to the latest 22 and the issue seemed to go away.
We are glad to hear that the problem is now solved.
