comarkiewicz
How to synchronize folder contents *after* pre-build events are completed?
I have a project where I would like to download a number of packages from Azure DevOps to a synchronized folder as a pre-build event *before* Advanced Installer synchronizes the folder. Currently, this is reversed, therefore the resulting installer does not contain the necessary files that I would like to install. Is there a way to run pre-build events before Advanced Installer synchronizes the folder?
Re: How to synchronize folder contents *after* pre-build events are completed?
As far as I know, the sync is the first thing that is done when the project is initialized (this is how the synchronization works).
The pre-build events are executed during the build, which can happen a lot after the project was initialized.
I will discuss this with the dev in charge to see whether there is something we can do here,
So far, an ideea that I got for the moment (please note I haven't tested it) is to build from the command line.
For instance, you could use our PowerShell automation support to do the loading and building of the project. I am thinking that by doing so, the project is no longer initialized and therefore the sync will not happen.
However, I am not so sure whether the synchronization will happen afterwards. :(
That being said, could you please give this a try and let me know how it goes?
