otalado
.json files are not deleted un uninstall
I have an issue: part of the install package is a pair of .json files (NET 8 app). I also have a SQLite file which is marked permanent. On uninstall the SQLite is (correctly) kept, however, the .json files are not deleted as they should be.
I have another app installed with Advanced Installer which has a pair of .json files in the install package and they get deleted on uninstall (as it should be).
So it is 99% sure I am doing something wrong. But I spend a lot of time trying to figure out what I have done differently and just can't find what! Any suggestion(s) where should I look will be welcome.
Re: .json files are not deleted un uninstall
Can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
Also let us know the names of files that are not removed during uninstall.
