MarcinK71
"Modify" installation issue.
Hi
I have installer with several different features, which user needs to pick from during installation installation. If he will select options from group MSFS, these components are not stored for future "modify" option. Groups marked as green works correct.
Screenshot 2024-11-15 093355.png (33.91 KiB) Viewed 3356 times
If I will install features from green marked options, they are saved for Modifying, the ones from MSFS group are not saved.
Why is that? Do I miss some sort of settings somewhere. Group MSFS was added later as first we had only first two groups to select from.
Thanks for pointing me in right direction.
Re: "Modify" installation issue.
Can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
MarcinK71
Hi
In the meantime I have updated to the latest version and now seems to be ok. I will do some more testing later today.
Its great to hear that everything is working now.
