According to event viewer, msiexec.exe is crashing. I've tried repair the insaller from the web. Running the installer with a log produces:
====== Starting logging of "C:\Users\tjohnson\Desktop\OMNIClientSetup.exe" ====
OS Version: 11.0.26100 SP0 (workstation) [x64]
CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
2024-12-10 10-04-26-Full command line:"C:\Users\tjohnson\Desktop\OMNIClientSetup.exe" /exelog c:\temp\OMNISetup.log
2024-12-10 10-04-26-Command line to pass to MSI:
2024-12-10 10-04-26-Extraction path set to:\\?\C:\Users\tjohnson\AppData\Roaming\MicroAutomation\Omni911 Call Taker SoftPhone 2.4.0.24341\install\
2024-12-10 10-04-26-Extraction path set to:\\?\C:\Users\tjohnson\AppData\Roaming\MicroAutomation\Omni911 Call Taker SoftPhone\prerequisites\
2024-12-10 10-04-26-Language used for UI:0-English (United States)
2024-12-10 10-04-26-Maintenance mode:false
2024-12-10 10-04-26-Searching for:.NET Framework 4.8.1
2024-12-10 10-04-26-Search result:An acceptable version was found.
2024-12-10 10-04-30-Code returned to Windows by setup:0
2024-12-10 10-04-30-=====================End of Log=====================
Her is the info from event viewer:
Faulting application name: msiexec.exe, version: 5.0.26100.712, time stamp: 0x858dc2bb
Faulting module name: msi.dll, version: 5.0.26100.2161, time stamp: 0x93942b33
Exception code: 0xc0000005
Fault offset: 0x00155fb2
Faulting process id: 0x4560
Faulting application start time: 0x1DB4B14C4F17D68
Faulting application path: C:\WINDOWS\SysWOW64\msiexec.exe
Faulting module path: C:\WINDOWS\System32\msi.dll
Report Id: 27f0e142-c5bb-4fc5-8fc9-bed8f62529f4
Faulting package full name:
Faulting package-relative application ID:
Any ideas?
