Paulklerkx
Missing Themes option and others from under "User Interface"
Hi, I have just upgraded to AI 22.3 and noticed I am missing a couple of options when opening a MSI Architect project. Is there something I need to do to see all the options? I'm not sure if they were there before, it has been a while since I looked through the options.
for example, under "User Interface" the only option I have is "Dialogs". Themes, slideshows and Translations used to be options in here I thought. These aren't options I use a lot, just thought I'd try a new theme, but then couldn't find the option.
Re: Missing Themes option and others from under "User Interface"
Hello Paul,
In the Architect edition of Advanced Installer, we have an option called "MSI Quick Edit".
Basically, you can right click on an MSI and then click the "Edit with Advanced Installer" context menu option.
However, please note that this is not intended to change major things in your package.
To do that, please open your Advanced Installer Project (AIP) file for said project and that should allow you to change the theme and pretty much everything else you need to do.
Paulklerkx
No, I'm not using the quick edit option. I am
  • opening advanced installer elevated from the start menu shortcut, then
    MSI Installer
    Installer Project - Architect
    Project Language - English United Kingdom
    Create new project
at this point, the only entry under "User Interface" is "Dialogs"
I get the same result with the process
    File
    Open
    myproject.aip - open
Hello Paul,
Please make sure you are not using the "Simple View" instead of "All features":
Paulklerkx
YES! that is it, thankyou, all back to normal.
You are always welcome!
