tdicosola
Conditional for Windows Server 2025
I'm using Advanced Installer 20.5
I have a custom action with the following condition:
(VersionNT64 = 1000 AND MsiNTProductType <> 1 AND WindowsBuild >= 20348)
this appears to NOT work on windows server 2025
I'm wondering if this is a limitation in the version of AI I'm using?
Does AI 20.5 NOT set VersionNT64 to 1000 for Server 2025 because its unaware of 2025?
Can I work around this without upgrading AI?
Tom
Re: Conditional for Windows Server 2025
Hello Tom and welcome to our forums,
Unfortunately, I do not have a Windows Server 2025 machine to test his on right now and therefore I can not really tell you what the value for VersionNT is in that version.
If possible, could you please run the installation on that server with the log enabled, e.g.:
msiexec /i package.msi /l*v myLog.txt
or:
setup.exe /l*v  myLog.txt
for EXE packages and check inside the log for the value?
Normally, the VersionNT is set by the Windows Installer - VersionNT property
Exception to that is Windows 11 as far as I'm aware as it is explained in the following article: How do I install resources based on the Operating System version?
