We are using Enterprise license and Predefined Prerequisites feature to install two .NET packages during MSI installation. The functionality works well, but the problems start when we started to build a project with Predefined Prerequisites feature as part of CI (Continuous Integration) process using Advanced Installer CLI.
As I understood correctly, Predefined Prerequisites work like the following: when I check one of the predefined prerequisite, it asks "download prerequisite and include in package?" and In our business use case this question requires to answer "Yes" for offline mode. After that, .NET package appears on a local disk on the machine where the checkbox was set.
But if we build as part of CI process in distributed way (on different machines), .NET packages do not exist if the checkbox was set on another machine. As I see, the only option to download .NET installers is to uncheck and check the package checkbox of required predefined prerequisites again on the machine where the project builds. I couldn't find a way to interact with Predefined Prerequisites feature via CLI, only via GUI.
In other words, our goal is to do the same steps as here (https://www.advancedinstaller.com/net-f ... stall.html) by answering "Yes" (offline mode), but using CLI.
Questions:
1) Is it possible to enable/disable predefined prerequisite package via CLI?
2) If no, are there any recommendations how to tackle this situation?
3) Is it possible to download predefined prerequisite during project building somehow?
4) Or the only option for offline mode for predefined prerequisites is to store artifacts somewhere in remote storage and download before building a project?
Thanks!
