angelaevans
How to conditionally install files and registry keys based on selected MSI feature?
Hi everyone,
In my MSI project, I have several optional features (like Core, PluginA, PluginB). What I want is:
If the user selects PluginA, only the related files and a registry entry should be installed.
If the user selects Plugin B, then its files and registry entries should be applied.
If none of the optional plugins are selected, only the core files should be installed.
I’m trying to figure out the best way in Advanced Installer to conditionally install both files and registry values based on the feature selection at install time.
Should I rely on Component conditions, or is there a more direct way to tie registry entries and files to specific features?
Any guidance or best practices would be really appreciated.
Thanks!
Re: How to conditionally install files and registry keys based on selected MSI feature?
If you have multiple files and registry keys, the best solution to allow the user to choose whether or not to install the feature is to use our predefined OptionalFeatsDlg dialog or use a a custom feature selection dialog.
In your case, just add the desired resources to PluginA and PluginB.
For this, add the resources to the MainFeature.
In the Organization page --> Feature Properties you can select the option to hide a feature from the dialog.
feature not displayed.png (42.63 KiB) Viewed 1835 times
