t.dev
How to change a subfolder source using command line?
Hello!
On my project, under Files and folders, there one specific folder that I need to modify the source and sync it using command line. The parent folders and all other files must remain intact. The structure is:
Application folder
- folder A
- folder B
- folder C
--folder C.1 -> I want to modify just the contents of this folder.
- file 1
- file 2
how can I do this?
Thank you!
Re: How to change a subfolder source using command line?
Hello and welcome to our forums.
In order to achieve this, you can synchronize your folder to a new path by using the "NewSync" command as detailed on the "New Synchronized Folder Command Option" page.
