I have a framework that all my other software products rely on. So far I have been able to distribute different versions of both the framework and the products separately, everything keeps working OK since the interfaces remain constant.
But now the 2.0 version of my framework no longer works with the 1.x versions of my products. So I want to create a number of launch conditions in the framework installer, to force the user to uninstall any old 1.x versions of the products.
Here's what I have tried so far:
- I created a search in the registry to get the version number of one of my products, for example 1.0.6. I wanted to create a launch condition to say "check if this version is smaller than 2.0". It looks like this is not possible. I would have to list all of the versions I have ever released, e.g. version = 1.0.0 or version = 1.0.1 or version = 1.0.2 etc... But this is a huge job to type in, some products have dozens of versions.
- I then noticed that file searches seemed to have some way to specify minimum and maximum version number, so I then tried the following: I created a registry search that returns the folder where the main executable for that product is installed. I called this PRODUCT_FOLDER and specified that it returns a folder path. I then created a file search that looks for the main executable, and I specified that folder as the location (from the properties dialog). This does not seem to work, it always returns empty.
- The standard file search does not seem like a valid option to me. I need to search for half a dozen products, and if we have to search all the drives on the machine then this can take half an hour. Searching the program files folder is not very reliable either, since the user may have chosen a completely different install folder.
I there any way to do this? I have so much information available in the registry, it seems silly that I can't use it now from AI. (I have the folder name, main filename, version number, and I still can't check if the product version is less than 2.0??)
If this can't be done, perhaps you could mark this down as a feature request: the < and > operators in the conditions should be able to compare version numbers.
Mat
