This is my first time here and I'd like to ask a question.
We've just bought Advanced Installer to create our installations packages. I'm trying to dynamically edit an XML file during the installation. I want to create a dialog for the user to enter with the number of server port. The installation package has to edit the XML file with the port entered by the user. How can I do this? I'm posting the XML file below. I just wanna change the "8080" in red with the port informed by the user during the installation process. Thank You.
<Server>
<!-- Use a custom version of StandardService that allows the
connectors to be started independent of the normal lifecycle
start to allow web apps to be deployed before starting the
connectors.
<Service name="jboss.web"
className="org.jboss.web.tomcat.tc5.StandardService">
<!-- A HTTP/1.1 Connector on port 8080 -->
<Connector port="8080" address="${jboss.bind.address}"
maxThreads="250" strategy="ms" maxHttpHeaderSize="8192"
emptySessionPath="true"
enableLookups="false" redirectPort="8443" acceptCount="100"
connectionTimeout="20000" disableUploadTimeout="true"/>
<!-- Add this option to the connector to avoid problems with
.NET clients that don't implement HTTP/1.1 correctly
restrictedUserAgents="^.*MS Web Services Client Protocol 1.1.4322.*$"
<!-- A AJP 1.3 Connector on port 8009 -->
<Connector port="8009" address="${jboss.bind.address}"
emptySessionPath="true" enableLookups="false" redirectPort="8443"
protocol="AJP/1.3"/>
<!-- SSL/TLS Connector configuration using the admin devl guide keystore
<Connector port="8443" address="${jboss.bind.address}"
maxThreads="100" strategy="ms" maxHttpHeaderSize="8192"
scheme="https" secure="true" clientAuth="false"
keystoreFile="${jboss.server.home.dir}/conf/chap8.keystore"
keystorePass="rmi+ssl" sslProtocol = "TLS" />
<Engine name="jboss.web" defaultHost="localhost">
<!-- The JAAS based authentication and authorization realm implementation
that is compatible with the jboss 3.2.x realm implementation.
- certificatePrincipal : the class name of the
org.jboss.security.auth.certs.CertificatePrincipal impl
used for mapping X509[] cert chains to a Princpal.
- allRolesMode : how to handle an auth-constraint with a role-name=*,
one of strict, authOnly, strictAuthOnly
+ strict = Use the strict servlet spec interpretation which requires
that the user have one of the web-app/security-role/role-name
+ authOnly = Allow any authenticated user
+ strictAuthOnly = Allow any authenticated user only if there are no
web-app/security-roles
<Realm className="org.jboss.web.tomcat.security.JBossSecurityMgrRealm"
certificatePrincipal="org.jboss.security.auth.certs.SubjectDNMapping"
allRolesMode="authOnly"
<!-- A subclass of JBossSecurityMgrRealm that uses the authentication
behavior of JBossSecurityMgrRealm, but overrides the authorization
checks to use JACC permissions with the current java.security.Policy
to determine authorized access.
<Realm className="org.jboss.web.tomcat.security.JaccAuthorizationRealm"
<Host name="localhost"
autoDeploy="false" deployOnStartup="false" deployXML="false"
configClass="org.jboss.web.tomcat.security.config.JBossContextConfig"
<!-- Uncomment to enable request dumper. This Valve "logs interesting
contents from the specified Request (before processing) and the
corresponding Response (after processing). It is especially useful
in debugging problems related to headers and cookies."
<Valve className="org.apache.catalina.valves.RequestDumperValve" />
<!-- Access logger -->
<Valve className="org.apache.catalina.valves.FastCommonAccessLogValve"
prefix="localhost_access_log." suffix=".log"
pattern="common" directory="${jboss.server.home.dir}/log"
resolveHosts="false" />
<!-- Uncomment to enable single sign-on across web apps
deployed to this host. Does not provide SSO across a cluster.
If this valve is used, do not use the JBoss ClusteredSingleSignOn
valve shown below.
A new configuration attribute is available beginning with
release 4.0.4:
cookieDomain configures the domain to which the SSO cookie
will be scoped (i.e. the set of hosts to
which the cookie will be presented). By default
the cookie is scoped to "/", meaning the host
that presented it. Set cookieDomain to a
wider domain (e.g. "xyz.com") to allow an SSO
to span more than one hostname.
<Valve className="org.apache.catalina.authenticator.SingleSignOn" />
deployed to this host AND to all other hosts in the cluster.
If this valve is used, do not use the standard Tomcat SingleSignOn
valve shown above.
Valve uses a JBossCache instance to support SSO credential
caching and replication across the cluster. The JBossCache
instance must be configured separately. By default, the valve
shares a JBossCache with the service that supports HttpSession
replication. See the "tc5-cluster-service.xml" file in the
server/all/deploy directory for cache configuration details.
Besides the attributes supported by the standard Tomcat
SingleSignOn valve (see the Tomcat docs), this version also
supports the following attributes:
cookieDomain see above
treeCacheName JMX ObjectName of the JBossCache MBean used to
support credential caching and replication across
the cluster. If not set, the default value is
"jboss.cache:service=TomcatClusteringCache", the
standard ObjectName of the JBossCache MBean used
to support session replication.
<Valve className="org.jboss.web.tomcat.tc5.sso.ClusteredSingleSignOn" />
<!-- Check for unclosed connections and transaction terminated checks
in servlets/jsps.
Important: The dependency on the CachedConnectionManager
in META-INF/jboss-service.xml must be uncommented, too
<Valve className="org.jboss.web.tomcat.tc5.jca.CachedConnectionValve"
cachedConnectionManagerObjectName="jboss.jca:service=CachedConnectionManager"
transactionManagerObjectName="jboss:service=TransactionManager" />
</Host>
</Engine>
</Service>
</Server>
