ewanb
Save As Template... For Merge Module Project?
Hi All,
We have lots of merge modules with very similar logic just different files so we don't want to have to repeatedly perform the same steps in AI. After checking out the docs I was sure "Save As Template..." would be the way forward but it seems to be disabled for merge module projects?
Is this intentional? Is there an easy way to get a copy of a merge module project with different GUIDs in it?
Ewan
ewanb
Re: Save As Template... For Merge Module Project?
OK, so seems I can answer my own question. Merge modules only have a single GUID which you can change by hitting the 'Generate' button on the 'Module Details' page. Then just make any other changes and hit 'Save As...'.
If this is wrong then please stop me because I'm about to generate a lot of merge modules :D
-Ewan
Cosmin
Hi Ewan,
Please note that the merge module also contains the GUIDs of the components in the Organization page. I'm afraid that currently Advanced Installer doesn't support a way for creating multiple merge modules from one template. However, I have added this feature on our TODO list and it will be available in a future version of Advanced Installer. Thank you for your suggestion.
Until then, there are two solutions:
1) create a different project for each merge module
2) manually modify all the GUIDs in the project
Cosmin
