sgh915
icon display problem in file association on win98
hi,
i have a terrible problem in win98.
when i creating new file, i need to show the my properly icon.
so i set my icon in display section in file association.
building is ok and installing is fine.
after that i try to create new icon, i can see the my icon.
how can i fix it?
help.
and urgent.
thx
so
Cosmin
Re: icon display problem in file association on win98
I'm not sure I understand the problem you are encountering. Can you please give me more details about this? Are you referring to the icon used by a file associated with your application? If so, what icon does it use?
Cosmin
sgh915
hi,
thank u for your help.
plz, check attach screenshot file.
Cosmin
Perhaps this behavior is caused by the Windows icon cache. If you double-click the file does it open in your application? If so, then the icon cache prevents Windows from showing the correct icon. If double-clicking the file doesn't open it in your application please send us the AIP you are using to support at advancedinstaller dot com so we can investigate it.
Cosmin
sgh915
of course, if i double click this file, my application open and it work fine.
so it is right u guess icon cache prevents windows from showing the icon.
how can i fix it in this case?
thx
ps.
anyway, i sent u my AIP.
please see it.
Cosmin
Although it may not work, you can try resetting the cache like this:
- right-click on the desktop and select the "Properties" menu
- in the "Display Properties" dialog go to the "Appearance" tab
- set the "Item" combo to "Icon"
- modify the "Size" field
For the computers you can try using a custom action to reset the cache during install, but I'm not sure how this custom action would look like.
Cosmin
sgh915
as u see second picture, when i set icon in file association and build it, it works fine in winxp.
but it doesnt work in win98.
when i create new file in desktop, i can see the broken icon in shortmenu.
and when i created new file, i can see the broken icon, is not my setting icon.
Cosmin
Unfortunately this behavior is caused by Windows 98, not by Windows Installer or by Advanced Installer. A workaround is to reset the icon cache like I suggested.
Cosmin
Return to “Feature Requests”
