nickr
String cut off in german translation
When running the re-install, the following dialog is shown in order to close any running applications.
I saw the following dialog box with the label cut off of a radio button:
Is there any way to fix this myself?
Cosmin
Re: String cut off in german translation
Unfortunately the size of the radio button control with the problem is set for only one row of text. To increase the size to two rows, you can try this:
For an Enterprise project:
- go to the "Dialogs" page
- select the "MsiRMFilesInUse" dialog in the "Special Dialogs" section
- select the radio button with the problem
- in its "Properties" pane set the "Height" to "20"
- rebuild the project
For a Professional project:
- go to the Advanced Installer installation folder (usually "C:\Program Files\Caphyon\Advanced Installer 6.9.1")
- go to the "fragments" subfolder
- open the "UI.aip" file with a text editor
- find the "caphyon.advinst.msicomp.MsiRadioButtonComponent" component
- for the "AppsShutdownOption" property with the "Value" set to "All" modify the "Height" to "20"
- the row should look like this:
<ROW Property="AppsShutdownOption" Order="1" Value="All" X="5" Y="5" Width="320" Height="20" TextLocId="RadioButton.Text.AppsShutdownOption#1"/>
- save and close the file
- close and reopen Advanced Installer
This problem will be fixed in the next version. Thank you for bringing this to our attention.
Cosmin
nickr
Thanks!
