guest
automatically upgrade
I was looking at the aip (xml) file...and am trying to figure out that each time i create a msi..it gives me
"another version of this installed" ..cannot continue.
which PROPERTY in the xml is used to compare this.
if i create the msi from the same aip file each time, do i need to bump it .
i have the "automcatically upgrade" the checkbox checked...
thanks
Cata
This message is given by Windows Installer, that uses the Product Code property. The Product Code property is changed on request every time the project version is modified.
Guest
re:
how can we upgrade the product code programatically. I want to put my own product code in there each time i build it.
thanks
Cata
That functionality is not exposed in the UI. We didn't see a reason to do so, actually.
A work-around would be to edit the .aip file by hand.
Cata
