Can u please let me know how to identify whether the checkbox is checked or not.
When the checkbox is selected, the "Properties" pane will show its properties. In this pane the "Property Name" field represents the property of the checkbox and the "Value" field represents the value of the property when the checkbox is checked. So the checkbox is checked if its property has the specified value. If the property is empty, the checkbox is not checked.
You can read about checkboxes
here.
Also on another note We need to show hide a EditBox control in the onclick event of the Checkbox.
This can be done by using
control conditions. The conditions can use the property of the checkbox. For example, if the checkbox has the property CHECK, this condition would be true when the checkbox is checked:
and this condition would be true when the checkbox is unchecked:
Cosmin
