First of all, the Execution Property for your DLL Custom Action must check for the return code. If this is the case, your DLL function must return a value of 0 (ERROR_SUCCESS) to indicate successful execution. Windows Installer interprets any other return value as failure and it will rollback.
Note that Windows Installer translates the return values from all actions when it writes those values into the log file. For example, if the action return value appears as 1 in the log file, this means that the action returned ERROR_SUCCESS. For more information about this translation see:
http://msdn.microsoft.com/library/defau ... values.asp
In order to determine the (translated) return value from (Standard or Custom) Actions it might be helpful to save the log file on disk. Use a command line similar to the following:
msiexec /i package.msi /L*V! "install.log"
In order to identify the return values open the generated log file and search for the following string: "Action ended" (without quotes).
Note that if your Custom Action is Deferred it will be executed at the end of the setup sequence.
Questions:
1. On which Standard Action is your DLL Custom Action scheduled?
2. The Execution Option is set to Immediate or Deferred?
If you have any questions, please let me know. You can also send the log file to support at advancedinstaller dot com so I can determine what the problem is.
Denis
