giacino
how to have custom icons for installed files?
I think/hope this is my last question and I will have my installer completed. I would like to thank the Advanced Installer support team and especially Denis for the quick and valuable responses that he sent to my previous questions.
My last question is:
One of the files that I am installing on users' system is a QuickTime Movie (".mov" extension). I would like to be able to associate a custom icon with that file. I have found the way to add a custom icon for the "Add/remove program" panel and for the installer itself, but I do not know how I can add custom icons to the files that I am installing. Any solutions?
As always thank you for your help and support!
Guillaume
Ionut
Thanks for the nice words :).
Actually, you can not associate a custom icon with a file that is not an EXE. You can associate a custom icon with all the files of a certain type (Quicktime ".mov" files in your case) but this is only recommended when your application associates itself with that file type.
I would recommend that you create a shortcut to that particular file (on the Desktop for example) and associate an icon with that shortcut (in the "New File Shortcut" dialog).
Denis
Denis Toma
Advanced Installer Team
giacino
Thanks for your answer. I definitely do not want to hijack the QuickTime MIME type, so I will most likely create a shortcut with my custom icon.
Thank you for your valuable recommendations.
Guillaume
