meetshashank
Need To Update Files
Hi Team-
We are using licensed version of AI. (Advanced and Best technology Singapore)
Below are some of my Queries:
We have our application folder structure like below.
Images Attached Here
Installer is placed in updates folder.
\ANBPAYROLL\UPDATES
When we run installer then it should update files in folder \IRAS. This is one level above the installer directory.
We need to update all files in IRAS folder except web.config (note we do not want to replace IRAS folder)
We crated Enterprise project type. Screenshot is attached below.
Sql scripts install properly but I am not sure how to add files in folder which is one level up to installer folder as mentioned above.
Please it’s very urgent.
Appreciate your reply.
Thanks in advance.
Many Thanks
Shashnak
mihai.petcu
Re: Need To Update Files
Hi Shashnak,
Here is an article to help you with this:
http://www.advancedinstaller.com/user-g ... older.html
To preserve files during an upgrade you can follow this user guide article:
http://www.advancedinstaller.com/user-g ... -file.html
meetshashank
Hi -
Thanks for Reply.
I am not able to figure out how to install files in custom folder.
Below is my directory Structure...
F:\ANBPAYROLL\UPDATES ..Where My Advance Installer is place..
Screen shot attached here... Attachment 1
Shashank
Attachment 1.JPG (98.79 KiB) Viewed 7730 times
F:\ANBPAYROLL\IRAS ...............Want to replace data in IRAS folder By running Setup in Updates Folder.
Which Option in files and Folder I can use?
Please its very urgent
Many Thanks
Shashank
Attachment 2.JPG (123.24 KiB) Viewed 7730 times
mihai.petcu
If you need to update an existing installation here's the recommended article you need to follow:
http://www.advancedinstaller.com/user-g ... oduct.html
You can easily set the installation folder of your Advanced Installer package from the Install Parameters page -> Application Folder field of your project.
Since you are new, I highly recommend you read our tutorials for a better understanding of how to use Advanced Installer to efficiently deploy your products.This will also help you better understand support team's suggestions now and in the future. The Simple and Professional tutorials are especially important.
meetshashank
Thanx for your reply.
I am able to get path and replace files in folder which i want. But issue is i am not able to place all folders /subfolders in target folder from source folder.
Any settings i need to do for this?
Many Thanks
Shashank
Hi Shashank,
Can you please give me more details? I don't understand exactly to which folders you are referring of.
meetshashank
Hi -
As shown above....I need to replace IR8A folder to client machine.
When i Run installer files get replaced at desired root location but not subfolders get repalced.
Any reason for this?
I am using File and Folders structure like below...
Many Thanks
Shashank
mihai.petcu
Hello Shashank,
Can you please send us the .AIPs( previous version and upgrade project files ) and their installation verbose logs to support at advancedinstaller dot com so we can investigate them?
meetshashank
Hi -
Solution is send.Please let me know i u need more details..
Many Thanks
Shashank
