DonInstall
Exclude From Uninstall...
Is there a way that when I compose an installer I can have one file that if the program is
uninstalled this especific file remains in the computer where the program was installed?
Maybe you're be asking why I want to do that. Well I want it to check if the program
will be install again.
Re: Exclude From Uninstall...
Hi and welcome to Advanced Installer forums,
If you want that a file to not be removed during uninstall you can mark its component as Permanent. This can be done in Organization page.
DonInstall
