I have two different shortcuts (one with arguments and one without) that I want to create depending on whether the MS Access runtime is installed (or will be installed by the installer). I am using the MS Access RT prerequisite and I've also found sections in the help that discusses exactly how to do this but I cannot get to the desired result after following the instructions (http://www.advancedinstaller.com/user-g ... tcuts.html) . At the moment, I have two folders under the desktop folder in "Files and Folders" (where the shortcut should be generated) with the property "install folder content into the parent folder" checked for each folder. Within each folder I have 1 shortcut. In "Organization" I have one component with the shortcut under the Main Feature and the other component under the MS Access RT Feature. I must be missing something simple because regardless of whether the MS AccessRT feature is installed or not, I always get the shortcut for the Main Feature. Is there a better way?
Thanks in advance for your help!
