davidrichens
Issue with Surface progress bar
I have just created a new installer using the new surface theme.
The installer will install the product successfully, but when it is on the progress dialogue of the copying files stage the bar goes up a tiny bit, then back to 0% then 1%.
It repeats this process all the way through, but interestingly, the progress bar on the windows tool bar at the bottom is working correctly.
Using Windows 7 x64
When I un-install the software, the progress bar works correctly.
Re: Issue with Surface progress bar
I'm afraid this is a normal Windows Installer behavior. We may improve this behavior in a future version of Advanced Installer, thank you for bringing it to our attention.
danswano
Hello, v9.6 didn't solve this issue, when you are going to fix it please? :(
Unfortunately, since these are the only requests the improvement was postponed due to low priority. Perhaps in the future we will increase its priority, but for the moment there are not immediate plans.
danswano
Oh no, can't you do it in the next release? or at least give me a temporary fix please :(
Windows 8 installer style is very important for my work and users are complaining about such bug.
Unfortunately the development member responsible with this part of application is out of the office until next week because is participating in a conference. I'll discuss about this improvement priority with him when comes back and I'll get back to you next week.
danswano
I hope you fix it soon, this theme is super awesome and simple, same UI as Visual Studio 2013 Installer and perfect for Windows 8. :D
I've discussed with the development team about this improvement and it seems the related issue is caused by Windows Installer. We have added this on our TODO list and will try to investigate the issue and maybe add an improvement in a future version of Advanced Installer. I'm afraid that we cannot offer an ETA for now.
danswano
Thank you very much, i hope it will be the next version. :)
mootie
Any updates? This seems like a pretty serious bug. I would like to buy a professional license, but the Surface theme is a very key feature for me.
I've increased the priority for this issue, but I'm afraid that we cannot give you an ETA for now. Thank you for your understanding. However, until then, as a workaround, you can proceed like this:
- Go to Dialogs page and select the "ProgressDlg" dialog from "First Time Install" tree node.
- Select the progress bar control and edit its subscribed event like this:
  • Subscribe To: Display overall installation progress (enhanced UI only)
    Attribute to set: Progress
- Build and run your project.
Let us know if this helped.
danswano
Did this problem got solved in v9.7 or not yet?
Thank you :)
No, unfortunately a fix for this issue wasn't added in version 9.7 of Advanced Installer.
Mahyar
the problem also happens if you use Styled Progress in surface theme ProgressDlg,
but another workaround I found is to use simple progressbar instead of Surface progess or Styled progress.
anyway we still wait for a fix :-)
skylinefighterx
Is there any resolution to this issue?
It still happens on 10.9
Not a very good UI, the progress bar should just go from left to right, and not jump back and forth.
