I'm in my trial period. My goal for this product is to produce an installer for a Tomcat web application, that will install or required JDK 1.7 and install Tomcat (if needed), then install a web application into the Tomcat7\webapps folder.
I created a Project using the Tomcat Webapp template. I have setup prerequisites for JDK 1.7 and Tomcat. This part seems clear enough.
Here are some of the problems I see:
1) We have experience that says we need to have the Tomcat installation avoid the use of blanks in the installation path. Thus, we need to override the default installation folder in the Tomcat installer. My guess is that this needs to handled by clear instructions for the person doing the installation, since this is controlled by the Tomcat installer provided.
2) The source directory for my webapp is named "sree", but I might need to use another name at installation time. This would allow me to install the same app side-by-side with another app (using different settings). How would I do that with your product? I don't see a way to control the installed name of the ApplicationFolder.
3) Does the Tomcat Webapp template automatically place the ApplicationFolder inside the Tomcat\webapps folder?
If this works out, I'll need to provide a convincing argument to management for the purchase of the Enterprise version.
We also have a few other installer applications the I would like to reduce the amount of time spent on creating installers.
Any additional help you could provide would be great.
Mark Northup
Sr. Software Developer
http://www.AssetPoint.com
