hitmany
Slider Image gallery - SELECT my Product Theme
How to make dialog message with Slider image gallery. If user select image and press Next button - get image number and unpack theme files to install directory.
Gallery like this:
Re: Slider Image gallery - SELECT my Product Theme
In order to achieve this you can create your own customized HTML page and display it through a "HTML Host Control". Also, as a workaround you can try the following scenario:
- Go to "Themes -> Settings" tab and enable our Enhanced UI feature.
- Go to "Custom Actions" page and add the following VBScript files as "Launch attached file" custom actions without sequence (eg. PreviousImageScript and NextImageScript):
Dim x
'Retrieve the value of MY_PROP
x = Session.Property("MY_PROP")
If x > 1 Then
  'Decrement x
  x = x-1
End If
'Write the decremented value back into MY_PROP
Session.Property("MY_PROP") = cstr(x)
'setting AiRefreshDlg refreshes the controls on a dialog when Enhanced UI is enabled
Session.Property("AiRefreshDlg") = cstr(1)
Dim x
If x < 3 Then
  'Increment x
  x = x+1
End If
'Write the incremented value back into MY_PROP
- Add a "Set installer property" custom action with sequence, scheduled before "Wizard Dialogs Stage -> Searches" action group, like this:
  • Property: MY_PROP
    Formatted: 1
- Go to "Dialogs" page and add a new dialog.
- Here add a image control (e.g. Bitmap_1) with the following control conditions:
  • Condition: MY_PROP = "1"
    Action: Show
    Condition: MY_PROP <> "1"
    Action: Hide
- Add a new image control (e.g. Bitmap_2) over the above image with the following control conditions:
  • Condition: MY_PROP = "2"
    Action: Show
    Condition: MY_PROP <> "2"
    Action: Hide
- Add another image control (e.g. Bitmap_3) over the above image with the following control conditions:
  • Condition: MY_PROP = "3"
    Action: Show
    Condition: MY_PROP <> "3"
    Action: Hide
- Add two button controls (Previous_Image and Next_Image) positioned under the above image controls.
- Select the above [Next_Image] button and add a published event like this:
  • Name: Execute custom action
    Argument: NextImageScript
- Then add two control conditions like this:
    Action: Disable
    Action: Enable
- Select the above [Previous_Image] button and add a published event like this:
    Argument: PreviousImageScript
    Action: Disable
    Action: Enable
- Build and run your project.
Also, you can add the related themes image files in "Files and Folders" view and condition their components installation, using MY_PROP property value, from "Organization -> Component Properties" right pane.
