Hello everyone,
I apologize in advance if this has already been asked but I could not find anything with my searching of these boards or the tutorials section ...
I need to have Adobe reader installed for my application. The version isn't very important to me ... I just need to make sure they have something installed that can view basic PDF files. Currently my installer has "Adobe Reader 9" checked, however, it appears to run into issues on Windows 8 if they already have Adobe Reader X (maybe XI) installed. So my questions are as follows:
1. Which options should I check for Adobe Reader? I assumed that if I wanted Adobe Reader 9 or newer I should simply checked Adobe Reader 9 but that does not appear to be the case.
2. Should I checked all Adobe Reader versions I accept? (9, X, XI)?
3. Is there a better way to handle this situation in general?
Thank you!
