eshiva
Service installation is not working
I am using the advanced installer 10.3 (Purchased version). I want to run my executable (.exe) as service from this installer. I added the relative fields in the service section. (Resources -> Services, Services to install, Control operations). Here i provided service file from the APPDIR (APPDIR\myservice.exe). Build the project. But during the installation i am getting a error like do not have the privilages (Please see attachment for error report).
And one more thing is i want to customize the Spring theme like i need browse dialog for installation path selection (instead of "InstallTypeDlg") and add the desktop, start menu shortcuts in the exit screen. Also exit screen has a checkbox for pc reboot, while selecting this checkbox PC has to reboot without any other dialog. I need MSI file. I am unable to customize the dialog boxes.
Shiva
Re: Service installation is not working
Can you please set the installation type, from "Install Parameters" page, to “Per-machine only( fails if user is not administrator)” and see if the behavior still persist? If so, can you please try to manually install and start the related service on target machine and see if it successfully starts?
You can delete the “InstallTypeDlg” and add the “ConfigureDlg” in the Install Sequence.
In order to achieve that you can add “ShortcutsDlg” predefined dialog in the Install Sequence.
You can take a look on “Create schortcut” article which may be helpful to you.
You can follow our “Restart the machine after the installation” how-to steps.
Also you can enable “Perform the reboot if required without showing any prompts” if you want to reboot automatically without prompting the user.
Please keep in mind that in order to build a MSI package you need to use the "Classic" theme. All others themes from our "Themes" page require our "Enhanced User Interface" feature to be enabled. Also, when the Enhanced UI feature is enabled, then the built package type it is mandatory be an EXE package.
eshiva
Hi Dan,
Installation type is already set to "Per-machine only( fails if user is not administrator)" only. Still i am getting this error. I am able to run, start and stop the service manually. Presently i am running service using batch file. During uninstall restart dialog box is appearing. How to remove this. I am stopping/removing the service using batch file but this uninstallation asking PC restart. (See attachment)
From the Files&Folder menu i can set shortcuts but these shortcuts only be displayed based on my checkbox selection and i want to make my own checkboxes for the shortcuts instead of using shortcuts dialog box.
eshiva
Hi Dan,
Based on above response i have chosen MSI package which has to be customized dialog boxes. Even though from classic theme i am unable to work with "InstallDlg", still it requires enhanced user interface. What should i do now. How can i achieve my requirements to modify the dialog boxes.
If i select "InstallDlg" from MSI installer, Licence agreement hyperlink is redirecting to some where else like "explorer.exe". Same project without any changes except package type= EXE is working fine. Whats the wrong in MSI.
And can you please tell me what i can achieve with "package type= MSI". I did not find any help documentation which tells for what feature EXE package is needed.
Shiva
Hi Dan,
This warning message appears when the service is already running. In order to avoid this warning message and stop the service if it is running you can go in the “Custom Actions” page and add our “Stop Service ” predefined custom action with sequence. Edit the “Service name:” label to the service that you need to be stopped.
You can add the “StopService” custom action in the installation sequence before the “Install Execution Stage” >> “Search” sequence.
You can create conditional shortcut which will be installed based on the user choice. You can take a look on Create Shortcut based on checkbox status thread which debates a similar issue.
Indeed, the “InstallDlg” requires the "Enhanced User Interface" feature to be enabled, therefore an EXE package type. In order to use an MSI package type you can delete the “InstallDlg” dialog and add instead the “FolderDlg” and the “LicenceAgreementDlg” dialogs.
We don't have a predefined article where you can find out what options are available depending the output package type(.msi or .exe), but every time when your package is set as a .msi and enable an option which require an .exe output, a waning message is displayed in the bottom-right corner of the Advanced Installer.
mknoblock
I have exactly the same problem: installing a service with an MSI, on a Windows 2012 target. The service is created and installed, but the installer hangs trying to start it. If you go into the Services Manager you can't start it manually either: "... failed to start. Verify that you have sufficient privileges to start system services".
If I go to the target machine and copy the service EXE I can install it with the command line, then start it with no problem in the SCM.
eshiva
Please resolve this issue ASAP.
See the attachment "Service_error.jpg" from first reply on this post.
Shiva
Please take a look on our Why do I receive the "Verify that you have sufficient privileges to start system services" message? FAQ which debates a similar issue.
