usgrcm
Property field to populate registry entry
Hey can someone tell me how i can do this? I want to modify a MSI I have created so that when i run the following
MSIEXEC.exe /i SomeMSI.MSI PROPERTY=BLAHBLAH
it will populate in the Value field of a registry key..
Thanks..
Re: Property field to populate registry entry
In order to achieve that you can go in the Install Parameters page and Create or edit a property(e.g. MY_PROP).
Then you can go in the Registry page, create your registry value and in the Data field your can have something like [MY_PROP].
So, when you are running your package from the command line you can use something like:
MSIEXEC.exe /i SomeMSI.MSI MY_PROP=”BLAHBLAH ”
