edd
Adding entries to 32 or 64 bit registry...
I understand how to add entries to the registry in Advanced Installer.
My question are:
Do these entries go to 32-bit or 64-bit registry when the client PC is running 64-bit Windows?
How can I force an entry to go to either 32-bit or 64-bit registry?
Reference:
http://msdn.microsoft.com/en-us/library ... s.85).aspx
redirector reflector virtual logical wow6432node mapped view shared node
mihai.petcu
Re: Adding entries to 32 or 64 bit registry...
Hi Edd and welcome to Advanced Installer forums,
Press F8 key while a registry value is selected in the Registry page. This will highlight its associated component in the Organization page where you can check 64-bit Component option. This will enable that registry value to be installed in the 64-bit portion of the registry on 64-bit machines instead of in Wow6432Node Registry Key.
How do I install different registry entries based on the Operating System (32/64-bit)? article can guide you further.
