jaelys
需要幫助及評估購買
您好,
目前正在評估放棄 Installshield 轉換成 Advanced Installer 來進行公司的封裝公作
主要原因為想讓此工作變得更容易,讓開發人員專注在開發過程中
在練習Advanced Installer封裝應用程式過程中是很享受的,但也受到很多挫折
1.語言問題是一個很大的學習阻礙
2.學習中,無法理解進階功能真正的使用方式及各種自定義功能如何設計
需求:
1.目前想要製作一個主要版本的安裝 + 可選資源安裝(可選或自動預設語系) +更新包(後續只維護此更新包並一起更新版本) 成為一個安裝檔案(單獨給客人)
2.靜默安裝(同上需求 or 更新包)可回饋進度給我們自行開發的應用程式可以偵測到進度及安裝狀態
不曉得以上兩個需求如何透過Advanced Installer來完成,讓我可以確認Advanced Installer符合需求,進行呈報並採購Advanced Installer為主要的唯一封裝工具
HI
i have some concern about your product of advanced installer for replace my department's installshield
the main idea of this purchasing plan is for our engineers will fully concentrate on their project without spend too much time on installshield.
because of your product (advanced installer) is really efficiency on this market.
1. the main problem of my concern is "language" (native language is Chinese)==>will be great if your product can produce Chinese edition.
2.during the advanced installer learning process, i wouldn't really figure out more advance function in custom action to achieve my project. ( i admit that not smart enough =.=)
requires:
1.i would like to design a main version of install package+ source package(choose or auto default by language) + update patch(can only conservation of patch and update the new edition of main version)= All the packages in one for my clients.
2.silent install (refer to the first require or update patch). will report me about result and procession or status for our own design application.
i was wondering if these two requires can complete by advanced installer and is it possible to have your help to direct me how to using advanced installer?
if there has any other way to satisfy my requires please reply asap. ( i would like to purchase advance installer asap for my company)
much appreciate and hope to hear from you soon
Jaelys Wu
Re: 需要幫助及評估購買
Hello Jaelys and welcome to Advanced Installer forums,
Currently the Advanced Installer application is released only in English language. Maybe in a future version we'll add a multilingual interface for Advanced Installer application, thank you for your suggestion.
Also, if you are referring to the language of the installation packages created with Advanced Installer application, then you can build setup packages which will use the Chinese language. All you have to do is to select the Chinese language from our "Start" page when creating an installation project. We have also support for creating multilingual installation packages.
Here is a list of articles you can follow in order to get a starting point for your scenario:
- Major upgrades
- Patches
- Patch Authoring
- Other Languages
Please take a look on our "Create a silent installation package" article which should be useful for you. Also, you can use our Updater tool which can be integrated with your application. Please take a look on our "Using The Updater" and "Integrate Updater In Application" articles.
We handle all technical issues through our forums or by e-mail. So, if you have any technical questions about how to build your installation package please do not hesitate to ask and we will gladly help you. You can send us an e-mail to support at advancedinstaller dot com or you can post your questions on our forums and we'll get back to you as soon as possible. Usually we reply in about 24 hours, excepting the week-ends, depending the tickets number we receive.
Also, since you are new, I highly recommend you read our tutorials for a better understanding of how to use Advanced Installer to efficiently deploy your products. This will also help you better understand support team's suggestions now and in the future. The Simple and Professional tutorials are especially important.
jaelys
Re: 需要幫助及評估購買
HI,
Sorry because of the relationship between language, I don't have a clearer indication of needs, Advanced Install tutorial is in English, resulting in my learning and assessment is hampered
Packaging requirements:
1. before installation check the current processes and services, shut down the process and service (looking into the custom action how to obtain property values, and learn how to obtain property values dialog box, in the operation, but to no avail)
2. installation, the language can be selected according to the start, mandatory installation of corresponding feature (I have five of the same resource, but language and style are different file groups, there can only be one automatically installed to the same directory)
3. after the installation is completed, links to patches or EXE in the same installation package (without using the online update) to update to the latest version (EX: main installation package version 1., I will deal only with patch packs to maintain up-to-date and version updates, and major version (1.0.0.0) issued a new client installations)
4. installation package can support all message languages? How commands like write? For example serial number validation error messages or the shortcut or the custom action type, I don't know how languages way (currently it appears to have found methods that can be set in the tests)
Silent packaging needs:
1. we have our own product management procedures, but through Advanced master installation we want Install package later, can have a place to easily get the installation progress and status, so that our product stewardship programs can complement and interact with customers in the UI, if not also not impact assessments,
Because we can use MSI original fill handle
Thanks again for your reply and guidance, if we assess the attractiveness of a business version, is it possible to be a Chinese tutorial or guide because I wanted it to be a relaxing work can be transferred to any employee
jaelys Wu
HI,
很抱歉礙於語言的關係,我沒有更清楚的說明需求,Advanced Install 的教程是英文,所以導致我的學習及評估受到阻礙
封裝需求:
1.安裝前先檢查當前進程及服務,存在則關閉進程及服務 (正研究自訂義動作如何取得屬性值,並學習如何取得屬性值做對話方塊的操作,但不成功)
2.安裝中,可依照一開始選擇的語系,強制安裝對應的功能 (我有五種相同資源,但語系及風格不同的檔案群組,只能有其中一種自動安裝至同一個目錄中)
3.主安裝完成後,連結同一安裝包中的補丁or EXE (不使用線上更新) 更新至最新版本 (EX:主安裝包版本為 1.0.0.0 ,我以後只處理補丁包內維持最新及版本更新,並永遠跟主版本(1.0.0.0)一起發給新客戶安裝)
4.安裝包所有訊息都可以支援語系? 請問命令須要如何寫? 例如序號驗證錯誤時或者自定義動作的訊息或者快捷方式文字,我不清楚如何語系化的方式(目前似乎已找到可以設置的方法,測試中)
靜默封裝需求:
1.我們有自己的產品管理程序,但主安裝我們希望透過 Advanced Install 封裝後,能有地方可以輕鬆的獲取安裝進度及狀態的方法,好讓我們的產品管理程序能補獲並跟客戶在UI互動,如果沒有也不影響評估,
因為我們可以使用MSI原始的補獲方式處理
再次謝謝您的回覆與指導,另請問如果我們評估購買企業版本,是否有可能會有中文教程或者指導,因為我希望這是一個輕鬆可以移轉的工作給任何員工
Re: 需要幫助及評估購買
Hello Jaelys,
Indeed, unfortunately we don't have a Chinese version of our documentation and user guide articles.
For this you can use our detect and stop processes and services custom actions. Also, you can take a look on our "Services and Processes" how to's.
In order to achieve this you can create a multilingual package and enable the "Display language selection dialog (for multi-language packages)" option. Then, you can configure your installation files as it is exposed in our "Install files with the same name" article and use the "ProductLanguage" property to condition their component installation. Also, you can take a look on our "Using files dependent of language" thread which debates a similar issue.
I'm afraid I don't fully understand your scenario. Can you please give usmore details about this (maybe exemplify)?
Unfortunately, we don't have localized values (in all languages) for all of our custom messages thrown by features like Serial Validation. Also, in order to localize an installer property or specific controls from your dialogs you can take a look on the following articles:
- Localize EULA and ReadMe text
- Localize a property's value
- Localize the project specific UI dialogs of a MSI package
I'm afraid I don't fully understand your requirement. Can you please give us an example about such functionality?
Unfortunately, currently we don't have any immediate plans for creating a Chinese version of our user guide articles and tutorials. However, if sometime in the future we'll add this task on our TODO list we'll let you know.
jaelys
Re: 需要幫助及評估購買
HI, Hello
Yes, I just have to find that article yesterday, and tested it, you should be able to meet the needs of different languages ​​the same resources, thank you for your guidance, I would read all the articles of the spend more time teaching
1 main installation package (1.0.0.0) fixed not upgraded after only do updates and patches to improve the version number of the way through, so I'll just need to (Main installation package + patches) released to the customer, you can publish only one patch the main version (1.0.0.0) update to the latest
Of course, I know that the patch has some limitations, also viewed some of the discussion forum, is there a better way to implement such a solution?
Or patches can be customized righteousness rather than differentiation implemented?
2. Use picture control Indirection of Indirect Property can support multi-language replaces a different picture?
3 When the silent installation, whether to provide progress and status back to the tool interfaces pass, that we could use (if you can use a custom DLL return property values​​?) In their applications, it is just a simple question ^ ^
Thank you for your guidance and advice
Jaelys WU
HI,您好
是的,我在昨天剛好也找到那些文章,並測試了一下,應該能滿足不同語系相同資源的需求,感謝您的指導,我會在花更多時間研讀所有教學章程
1.主安裝包 (1.0.0.0) 固定不在升級,以後只透過補丁的方式來做更新及提升版本號,這樣我以後只需要(主安裝包 + 補釘) 發佈給客戶,也可以只發佈一個補丁把主版本(1.0.0.0)更新到最新
當然我知道補丁有一些限制,也查看過論壇一些討論,是否有更佳的做法來實現這樣的流程?
或者補丁可自訂義而不是差異化實作?
2.圖片控件的Use Indirection 的 Indirect Property 能否支援多國語系替換不同的圖片?
3.靜默安裝時,是否有提供進度及狀態回傳接口的工具,可供我們在自己的應用程序中使用(是否可使用自定義DLL回傳屬性值?),這只是個單純的提問^^
非常感謝您的指導與建議
Jaelys Wu
Re: 需要幫助及評估購買
Hello Jaelys,
In order to achieve this you can use our "Updater" tool.
Indeed, when creating patches you should fulfill all patches rules. However, if you don't want to create your updates packages as patches, then you can create major upgrade packages.
In order to achieve this you can proceed as following:
- go to "Themes" -> "Images" tab and add two images like this:
  • Images Path: EnglishImage
    Property Name: EN_IMG
    Images Path: ChineseImage
    Property Name: CH_IMG
- go to "Custom Actions" page and add a "Set installer property" custom actions with sequence, scheduled before "Wizard Dialogs Stage" -> "Searches" action group, like this:
  • Property: EN_IMG
    Formatted: [CH_IMG]
    Condition: UserLanguageID = 2052
- go to "Dialogs" page, select your image control and in the "Properties" right pane configure it as following:
  • Use Indirection: True
    Indirect Property: ImgEn
-Build and run your project.
Please take a look on our "How do I collect installation data and send it to my web server?" article which should be useful for you.
jaelys
Re: 需要幫助及評估購買
HI,
These days, try a picture, change the resource by selecting the language change has been tested successfully, very perfect, thank you for your guidance again.
Another encounter two problems:
1 out of the installation process the message window (Cannot run script. Transaction no started) can not be solved
2 My installation package as a unified package, optional language menu, but when removed, always in English language, other languages ​​are not the original choice, if there is a more correct approach?
3 My installation process, the progress of rolling a bit strange and messages displayed are extremely rare, but I did not do a lot of features, only REG is written, firewall settings (schedule will always beat at the beginning)
HI,
這幾天嘗試了圖片、資源透過選擇語系變更而改變,已測試成功,非常完美,再次感謝您的指導。
另碰到兩個問題:
1.安裝過程時跳出訊息視窗(Cannot run script. Transaction no started) 無法解決
2.我的安裝包為統一的包,可選的語系選單,但在移除時,總是英文語系,並非當初選擇的其他語系,是否有更正確的做法?
3.我的安裝過程中,進度滾動的有點怪及訊息顯示的特別少,但我並沒有做很多功能,只有登陸檔寫入,防火牆設置(進度會一直跳動在一開始)
Re: 需要幫助及評估購買
Can you please tell us when do you get the above error message? It is during your package installation? If so, please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
2 My installation package as a unified package, optional language menu, but when removed, always in English language, other languages ??are not the original choice, if there is a more correct approach?
This may happen if you are using different Product Codes for your installation languages. Can you please proceed like this:
- go to "Product Details -> Product IDs" tab and set the same Product Code for all of your installation languages
- build and run your project
and see if the behavior still replicates?
I'm afraid I don't fully understand your scenario. Can you please give us more details about this (maybe exemplify)?
jaelys
Re: 需要幫助及評估購買
HI
1 out of the installation process Cannot run script. Transaction no started the problem, I repeated the test, the reason seems to be the production version 10.71, but then I upgraded to 10.8 trial has been rebuild will occur,
     Then I re-use version 10.8 reopen a new test project, the problem does not happen again
2 Another would like to ask, the leading pre-installation EXE UI pops up whether to change the style or design?
3 I have a Standard Edition, Professional Edition, OEM version want to design in one package, with custom serial number and SKU write MsiSetProperty (hInstall, _T ("AI_SKU_ID"), skuID), but I have been unable to successfully ask detailed Why is the right approach?
    AI_SKU_ID be wrong, I use AI_SKU_IDX not an error, but could not succeed (because I found seemed to establish SKU will automatically increase Search a AI_SKU_IDX, but the default search Software \ [Manufacturer] \ [ProductCode] and AI_SKU_IDX)
    And if I remove the Search inside AI_SKU_IDX, will crash when the project is saved!!
ex:
Feature Base (certain major version installed)
     Feature Pro (increase and replace the main program) SKU specified, do not show hidden
     Feature OEM (increase and replace the main program) SKU specified, do not show hidden
1. 安裝過程跳出Cannot run script. Transaction no started的問題,我反覆測試,原因好像是 10.71版本製作的,後來我升級到10.8試用,重新建置就一直會發生,
後來我重新用10.8版本重新開啟一個新專案測試,問題沒有再發生過
2.另想請問,前導EXE預安裝所跳出的UI風格是否可變更或設計?
3.我有標準版、專業版、OEM版本想設計在同一個安裝包,透過SKU 並自定義序列號寫MsiSetProperty(hInstall, _T("AI_SKU_ID"), skuID),但我一直無法成功,請問詳細正確的做法為何?
AI_SKU_ID 會錯誤,我使用AI_SKU_IDX 不會錯誤,但無法成功 (因為我發現好像建立SKU就會自動增加Search一個AI_SKU_IDX,但預設搜尋Software\[Manufacturer]\[ProductCode]和AI_SKU_IDX)
並且如果我刪除了Search裡面的AI_SKU_IDX,專案儲存時會崩潰!!
ex:
Feature Base (一定安裝的主要版本)
Feature Pro (增加及替換主程式) SKU 指定,隱藏不顯示
Feature OEM (增加及替換主程式) SKU 指定,隱藏不顯示
Re: 需要幫助及評估購買
You can change your dialogs themes from our "Themes" page. Let us know if this helped, otherwise please give us more details about what you are trying to achieve (maybe exemplify).
ex:
In order to achieve this you should create in "Organization" page three features (e.g. Feature Base, Feature Pro and Feature OEM) and then, create SKUs in "Stock Keeping Units" page which will be associated accordingly with your features. Then, within your custom serial number validation DLL, you should check the serial number entered by the user (PIDKEY property value) and set the "SERIAL_VALIDATION" property to TRUE is the serial number is valid, or to FALSE otherwise. Also, if the serial number is valid you should set accordingly the "AI_SKU_ID" property to the ID of the SKU associated with entered serial number.
jaelys
Re: 需要幫助及評估購買
HI,
 Sorry to say I should be careful enough
1 will jump out of a window when the pre-installed , whether this window styles can be designed ?
2.Chained Package with the main MSI how to properly when removed, along with removal ( default REMOVE = "ALL", UI BASE is removed ) , and the other I set up ARPSYSTEMCOMPONENT = 1 but will still appear in the console unless I the Chained Package covers hide the console before the project is not checked
In order to achieve this, you should build in the " organization" page three features ( such as library features, functions and features of Pro OEM), and then create SKU 's " stock keeping unit " will accordingly be functionally related to your page. Then , your custom DLL to verify the serial number , you should check the user (PIDKEY property value ) enter the serial number and "SERIAL_VALIDATION" property is set to TRUE is the serial number is valid, or else return FALSE. In addition, if the serial number is valid, you should set the appropriate "AI_SKU_ID" attribute to identify the SKU and enter the serial number associated with it. All the best, Daniel
I was right to do so , but did not succeed as expected , at the beginning I was MsiSetProperty (hInstall, _T (" AI_SKU_ID [/ b]"), skuID), will collapse , later changed MsiSetProperty (hInstall, _T ("AI_SKU_IDX"), skuID), it can run , but the function was not installed correctly , even MainFeature none installed
Another search will be more than two AI_SKU_IDX, if I delete one , save, the program will error
[SEH_AV_DEP_BADPTR] ACCESS_VIOLATION (0xc0000005) at address [0x00000f00]
Advanced Installer 10.8 build 54215
*** Stack Trace (x86) ***
[0x00000f00] -----
[0x019d16d3] -----
[0x6d0b2118] DllCanUnloadNow ()
[0x01522a9b] -----
[0x01250000] MODULE_BASE_ADDRESS
ex:
MainFeature (main.exe, base.txt) must be installed
Feature Pro ( replace main.exe, increase pro.txt) from SKU specify this feature and want to hide do not give customers choice
Feature OEM ( replace main.exe, increase Oem.txt) from SKU specify this feature and want to hide do not give customers choice
Thank you for your guidance, this part of the test is to assess the final step , after the test project properly, I will report the results to the boss to do procurement
Jaelys
HI,
很抱歉應該是我說的不夠仔細
1.預先安裝時會跳出一個視窗,此視窗風格是否可被設計?
2.Chained Package 如何正確的隨主MSI移除時,一起移除(預設REMOVE = "ALL",移除時 UI BASE),另我設置了ARPSYSTEMCOMPONENT=1但還是會顯示在控制台,除非我把Chained Package 的覆蓋控制台項目 不勾選才可隱藏
為了實現這一點,你應該建立在“組織”頁三防功能(例如特徵庫,功能Pro和特點OEM),然後在創建SKU的“庫存單位”,將相應地與您進行功能相關的頁面。然後,您的自定義序列號驗證DLL中,你應該檢查用戶(PIDKEY屬性值)輸入序列號和“SERIAL_VALIDATION”屬性設置為TRUE是序列號是有效的,或者否則返回FALSE。此外,如果序列號有效,你應該設置相應的“AI_SKU_ID”屬性來標識的SKU與輸入的序列號相關聯。一切順利,丹尼爾
我是如此做沒錯,但並沒有如預期的成功,一開始我是MsiSetProperty (hInstall, _T ("AI_SKU_ID"), skuID),會崩潰,後來改為MsiSetProperty (hInstall, _T ("AI_SKU_IDX"), skuID),可運行,但功能並沒有正確安裝,連MainFeature都未裝
另外搜尋會多了兩個AI_SKU_IDX,如果我刪除其中一個,保存時,程序都會報錯
[0x00000f00] -----
[0x019d16d3] -----
[0x6d0b2118] DllCanUnloadNow()
[0x01522a9b] -----
ex:
MainFeature (main.exe、base.txt) 必須安裝
Feature Pro (替換main.exe、增加 pro.txt) 已從SKU指定此功能,並且想隱藏不給客戶選擇
Feature OEM (替換main.exe、增加 Oem.txt) 已從SKU指定此功能,並且想隱藏不給客戶選擇
感謝您的指導,這部分是評估測試最後一步了,測試專案正常後,我將呈報結果給上司做採購
Jaelys
Re: 需要幫助及評估購買
Hello Jaelys,
I'm afraid we don't have support for editing the text style of the pre-install prerequisites wizard dialogs.
I'm afraid I don't fully understand what you mean. Can you please give us more details about this (maybe exemplify).
I've tested your scenario and I can replicate the behavior. This seems to be an Advanced Installer issue, thank you for bringing this to our attention. A fix will be available in our next version of Advanced Installer. We'll notify you when it will be released. Until then, if you need a fix you can send us an e-mail to support at advancedinstaller dot com and will send you a fix for this issue.
jaelys
Re: 需要幫助及評估購買
Hi
Figure I can do to change their own ex: Replacing the default installation of advanced picture ?
Enterprise Edition will soon be purchasing, installation is expected to be better advanced products , thank you for your help guide so that I can quickly perform testing and evaluation , I will wait for the completion of the final test repaired again , thank you for .
1 I want to remove the main installation , Chained Package ( console is not visible, remove the condition REMOVE = "ALL", when remove the UI is set to UI BASE) can be automatically removed , but always unsuccessful, right Why practice ?
   Also Chained Package MSI If you set the project " overwrite Windows Install ", even though I set ARPSYSTEMCOMPONENT = 1, add or remove a list of console visible
Hi
我能夠自行換圖嗎? ex:更換先進安裝內預設的圖片?
近期將進行企業版的採購,預期先進安裝將是更棒的產品,感謝您的協助指導,讓我可以快速的進行測試評估,我會等待修復好再次完成最後的測試,感謝您。
1.我想讓主安裝移除時,Chained Package (控制台不可見,移除條件 REMOVE = "ALL",移除時UI設置為 UI BASE) 可以自動移除,但總是不成功,正確的做法為何?
另外 Chained Package MSI 如果設置了覆蓋 Windows Install 項目,即使我設置了ARPSYSTEMCOMPONENT=1,在新增移除列表控制台還是可見狀態
Re: 需要幫助及評估購買
In order to achieve this you can change the icon file from "Themes page -> Preview tab -> More Options -> Customizable Images section".
Do you mean that, during uninstall of the main package, your chained package uninstallation fails? In order to get more details about this you can enable the "Logging" option from "Prerquisites" page for your chained package and send us the log file so we can investigate. Also, you can try to manually install and uninstall the chained package and see if the behavior persist.
In order to achieve this you should enable the "Do not show in list" option from "Product Details" page. Also, you should disable the "Override Windows Installer programs list entry" option.
jaelys
Re: 需要幫助及評估購買
HI,
So far the problem before, are in perfect working
1 currently encountered in covering Windows Installer custom name: [| PRODUCTVERNAME], but does not work, Add / Remove shows the default [| ProductName]
2 I use the "Display remaining time for current progress" when such events display, UI is often anti-white flashes, how to improve?
3.Package of sub-functions (Resource_xx), originally set up to judge all my language and functional status (! EA = 3) in order to install, before you can be, do not know why die later
Later, I only set a Resource_tw not set conditions, or not installed correctly, can you please guide, thank you
4.
Select feature is not work.
HI,
之前的問題到目前為止,都已完美的工作
1.目前碰到在覆蓋 Windows Installer 的自訂名稱 :[|PRODUCTVERNAME],但是不工作,Add/Remove 顯示的是預設 [|ProductName]
2.我使用 "Display remaining time for current progress" 這類事件顯示時,UI常常反白閃爍,如何改善?
