Blackis
Install 5 programs in sequence ?
Hello, after reading what kind of questions being asked here i hope you guys don't shove me out of the internet ^^
I understand that this program makes installers of files already installed..
But i want the program to take my 15 installers (.exe) and then install them with reboots and all that they want, and keep installing the other .exe's after the reboot/s
Is this possible to do with advanced installer ?
Why do i want to do this?
Because after i have reinstalled windows i want my single .msi-file to install my firewall software, anti-virus, then just other things in one click or maybe more like 5 but yea.
I look forward to see what kind-off reply's i will get on this ^^
And if im totally in the woods maybe some kind sole can point me in the right direction :ugeek:
Re: Install 5 programs in sequence ?
In order to achieve that, you can add the related installation packages as a prerequisite in the Prerequisites page. You can also take a look on the Add Prerequisite article which may help you.
If the related is not in our predefined list the you can add it using:
- [ New Package Prerequisite ] toolbar button to create a new prerequisite using files from disk.
- [ New URL Prerequisite ] toolbar button and add the download URL of the prerequisite.
Please keep in mind that this type of prerequisite is created with default settings, so you need to configure it manually. The best way to see what install conditions you should use is to install the prerequisites on a clean machine and see what changes take place. If you don't do this, after installing your prerequisites you might receive the Required Application prerequisite was not correctly installed... message.
Usually the easiest way is to see changes that affect the registry hive, HKCU or HKLM. You can also see if certain files are installed on the machine, for example a specific DLL file or EXE and search for them in the Install Conditions tab, Searches group.
If you need to reboot your machine after a certain prerequisite installation, then you can add the related installation packages in the Pre-Install section from the Prerequisites page and enable the Reboot system after installing this prerequisite option from the Prerequisite properties tab.
Blackis
I give my thanks to u Dan for the quick reply! =)
I have read the link's so now i will have a few hours of testing and so on :geek: :mrgreen:
I'll get back to u with my results if anyone wish to know how easy or hard it was =)
Blackis
That was very easy, i did 4 installers, and used trial by error ^^
At first i took all my .exe's in to the msi from start with the wizard, but it was easier to add them one by one in prerequisites :lol:
I can just say that i start to understand this program and i will do more of this, so cya later guys :D
PS: Ty very very mush Dan! :ugeek:
You're welcome,
If there is anything else I can help with, please let me know.
