Hello Rohit and welcome to Advanced Installer forums,
Also any outlook version may be installed on the target computer from office 2003 to office 2013 or 365.
In order to achieve that, you can go in the
Search page and create a
Registry value with a specified content -
Extended Search. The result is given by the presence of a registry value with a certain content. You will be given the option to specify how the comparison is made. If the search is successfully, then the property assigned to the
Search operation will be set, otherwise it will be empty.
You can take a look om the below image to have a better view about this:
- Search Outlook.png (12.31 KiB) Viewed 41618 times
So, you can add a search for each version of Microsoft Office and also check for each
Bitness value: x86 or the x64 version.
If Outlook bitness value is x86 then install 32bit.dll and if it is x64 then install 64bit.dll
Please note that once you had added the DLLs to your installation package, a new component has been created in the
Organization page.
So, you can add your search name in the
Condition field of the related
component
e.g.
For the component associated with the 32bit dll you can have something like that in the condition field:
OUTLOOK_32_OFFICE2003 OR OUTLOOK_32_OFFICE2007 OR OUTLOOK_32_OFFICE20010 OR OUTLOOK_32_OFFICE2013 OR OUTLOOK_32_OFFICE365
where OUTLOOK_32_OFFICE2003 and OUTLOOK_32_OFFICE2007 and so on are the
public properties associated with your searches from the
Search page.
So, if any of these searches is true then your .32 bit DLL should get installed.
Add something similar for the 64 bit dll.
Please let us know if you have other questions.
