vesselin.denev
Feature folder
Hi All,
I need some help with getting something done in advanced installer.
I have two features in my installer. Under Files and Folders -> Application Folder I have several subfolders. All but one of those are associated with FeatureA. FeatureB has one of those folders assigned to it.
When I install with both features enabled, in my installation folder I get all the structure that is under Application Folder. And that is fine.
What I am trying to achieve is when FeatureA is disabled (not being installed) the files form FeatureB to be installed under APPDIR. Instead at the moment they are installed under APPDIR/foldername, where folder name is the folder that I have under Application folders and is assigned to featureB.
Does anyone have any ideas?
Probably I need to use a property based folder for featureB, but so far I've been unable to make it work.
Thanks in advance.
Kind Regards,
Vesselin Denev
Re: Feature folder
Hi Vesselin,
Please enable the Install folder content into the parent folder option from the Properties tab of the Edit Folder dialog.
When this option is enabled, the folder content will be installed into its parent folder.
vesselin.denev
Re: Feature folder
Hi Dan,
Thank you for the reply.
I can't seem to get this working with your suggestion.
FeatureB should always be installed (it is a mandatory one). Only the folder changes.
If FeatureA is marked for installation FeatureB should be installed in APPDIR/subfolder.
If FeatureA is not being installed FeatureB should be installed in APPDIR.
Do you know how to get this one done?
Kind Regards,
Vesselin Denev
Re: Feature folder
Hi Vesselin,
In this case, you can create two folders with the same content for feature B. One folder will have the Install folder content into the parent folder option enabled, the other one will not have it.
Then, in the Organization view, create a new subfeature and assign each folder from the previous created ones with a subfeature.
Condition the subfeature installation based on the feature A state. If the feature A will be installed, then install the subfeature of B that has assign the folder that doesn't have the Install folder content into the parent folder option enabled. When feature A is not scheduled to be installed, then install subfeature of B which has assign the folder that has the Install folder content into the parent folder option enabled.
vesselin.denev
Re: Feature folder
Hi Dan,
Thanks again.
This is exactly what I needed.
Kind Regards,
Vesselin Denev
Re: Feature folder
You're welcome Vesselin,
narsingani
Re: Feature folder
Can someone explain what are these under Feature folder? Ho can I remove these?
Thanks!
Upendra
Advanced Installer.jpg (16.78 KiB) Viewed 6149 times
Re: Feature folder
Hello Upendra,
The related items are the components contained by the feature. A component is automatically removed when all its contained resource files are moved into another component.
