AKR
Shortcut and files depending on the language
1) How to create a shortcut depending on the language?
2) How to install the file, depending on the language?
You must sutsnovit program supports two languages English and Russian.
During installation, depending on the chosen language must create a shortcut to the manual (documentation). Shortcuts name must be in the selected language.
Or create a link, depending on the language.
More would be good to establish a file with documentation only in the selected language.
Re: Shortcut and files depending on the language
You can add two separate shortcuts to your installed help files and condition each of their components in the Organization page with the ProductLanguage property. You can use our "Test if the language of the installation matches the one you specify" predefined condition from the Edit Condition dialog.
Also, here is the how to that can help you install two files with the same name in the same location.
This way when you install your package only one shortcut will be installed.
AKR
Thank you! That should work.
I found related topic in the forum:
Creating shortcut for specific language only
You're welcome,
AKR
How to make so that the files are installed, but the shortcut was created, depending on the localization of the system?
It is necessary that the file was installed anyway.
But the shortcut was created only for specific location.
To achieve what you want you should create your shortcuts as shortcuts to an external file and move each one of them into dummy components. Then you can condition the dummy components installation as you need.
A regular shortcut cannot be moved from its target file component and this is why you should create your shortcuts as shortcuts to external files.
AKR
Thank you very much, so works!
You're always welcome.
