divyaniP
Batch file(Custom action) error on next button before installation
I have added custom action having a batch file as mentioned in this link: https://www.advancedinstaller.com/user- ... te-ca.html
If I make this custom action with sequence and use run in install execution stage then it runs well.
But when I make this custom action without sequence and trigger it on the next button of any dialog as a published event, then it gives an error like this :
"There is a problem with this windows installer package. A program run as a part of a setup did not finish as expected. Contact your support personnel or package vendor."
I want to run this batch file before installation.
I have added a screenshot of my custom action.
How can I make this custom action run on the next button of the dialog before clicking on the Install button?
Re: Batch file(Custom action) error on next button before installation
Most likely, this is happening due to the fact that at the time your custom action is executed, the file is not present on the machine.
In order to work this around, you can add your .BAT file as a temporary file.
Unlike Advanced Installer's regular files or resources, "Temporary Files" are copied on the target machine at the beginning of the installation and are deleted at the end of it, ensuring you have access to them throughout the entire install process.
divyaniP
Thank you for your help Catalin :)
Now we can execute that batch file.
You are always welcome! :)
I am glad to hear everything works as expected now.
